External Choices
1132
12-22-2022 08:49 AM
SeanWalsh
I have a survey that I want to use choice filters for four dropdowns.  The last dropdown is a large list and I read if there are over 500 choices then it should be an external list.  I've ready about external selects and external choices but I am not sure which one to choose. I tried using select_one_from_file but when the survey updated everything was blank.  I tried adding external_choices tab but I couldn't get that to work either.  Pardon me as I've only been using Survey for a few weeks now.
I already have it setup so the first dropdown changes the options for the second dropdown and I can use the same coding to filter the third.  I am not sure how to setup the fourth option considering there is almost 1000 choices.
ZacharySutherby
Hello @SeanWalsh
Attached is a sample that demonstrates both external selects & external choices.
Thank you,
Zach
ZacharySutherby
Hello @SeanWalsh
Thank you,
Zach
