Export Survey123 Data to Excel using fieldAlias from ArcEnterprise
306
03-19-2026 08:05 PM
AKitch
I used to export Survey123 data via ArcGIS Online (https://survey123.arcgis.com) which used to use the fieldAlias setting. I have now moved to ArcEnterprise and my Survey123 exports to Excel are using the 'name' column for the fields. This is despite displaying the fieldAlias in the Survery123 website as well as in the ArcEnterprise portal. Is there a setting in ArcEnterprise that will make Survey123 exports use the fieldAlias setting?
