export ipad number to survey 123
930
02-11-2018 03:49 PM
AnuSawant
Hi there,
I have survey in number format (excel version of ipad...i guess???) which has got all the drop downs attached to the fields. Is there any way I can export that to Survey 123 connect with all of the options or do I have to manually add them to "choices.sheet" to excel.
Anu
IsmaelChivite
Esri Notable Contributor
The syntax to create dropdown lists in Survey123 is defined by the XLSForm specification.  The syntax is well defined and strictly enforced. You will want to follow instructions as shown in this video tutorial.  Our XLSForms Essentials help topic is also a good reference.  In terms of importing lists into an XLSForm document, you can play all tricks you want in Microsoft Excel or the XLS editor of your choice, as long as you define your lists according to the XLSForm specification.  For example, you can copy and paste values from other spreadsheets, you can import data from external sources, use formulas etc...  All is fair game, again, as long as you follow the XLSForm rules for choice lists: They get stored in the choices  worksheet and require at least three columns: list_name, name and label.
AnuSawant
Thanks Ismael.
