Error with repeats
2890
05-24-2021 12:46 AM
ahmad_sidani
Hello dears,
I created a complicated survey with 7 repeats, everything seems working fine except for 1 repeat where I need to know the count of selected options.
Please I need your support in figuring out the issue 😄
Attached is the XLS form in which I highlighted the suspected error as well as the error received.
Thanks in advance.
DougBrowning
MVP Esteemed Contributor
Turn on Error logging in the app settings - that will give a lot more info to go on.
Hussam_AlJabri
Hi Ahmed,
I noticed some errors in your xlsform and I converted it to the new version then publish it without errors.
see the attached enhanced form and let me know if you need support on it.
ahmad_sidani
Dear Hussam,
Thanks for your support 😄
I was able to publish the survey but I don't know why its not shown properly ( questions are mixed in a different sequence) , I am sharing a screenshot but I don't know if I stated the issue clearly.
Thanks again dear.
Hussam_AlJabri
The sequence should be reflect the one which is in your xlsform. I will look at it again and compare with your old survey.
