Error Initializing form..
1618
11-20-2024 02:18 AM
JoCondliffe
I'm getting an error on a published form created in Survey123 Connect saying "Cannot read properties of undefined (reading 'on')".
The form is fine in Survey123 Connect but throws the error when viewing in browser. Is anyone else experiencing this or know what the problem might be?
Thanks
CodyPatterson
MVP Regular Contributor
Hey @JoCondliffe
Would it be possible to attach the XLS to the post? I believe there may be a variable or an incorrect value associated with "on" that could be throwing this error. You may want to Ctrl + F to see if you can find all instances of "on" and see if there is an issue somewhere in the code.
Cody
CodyPatterson
Hey @JoCondliffe
Cody
JoCondliffe
Hi @CodyPatterson, solved the problem (kind of). Yes it appeared to be an issue with a calculation, not sure what changed as it was working yesterday and survey123 connect didn't show an issue. I removed it in the end as it was just to create some additional content and I decided it's easier to process via Python after submission.
