Error: Failed to submit -does not have z-values
260
10-30-2025 09:10 AM
SD11
Survey published fine with a Locations question with Map set up collect polygon features. Following error pops up. Looking for solution that would fix it. I have tried saving as a copy and re established the location question but get the same following error.
{"error":{"code":400,"message":"","details":["'edits' parameter is invalid","The specified geometry is not in the correct format. Geometry does not have z-values","Unable to apply edits."]}}
Neal_t_k
Are Z values required in your source feature layer?  In the "bind::esri:fieldType" field try putting "esriFieldTypePointZ"
https://community.esri.com/t5/arcgis-survey123-blog/working-with-z-values-in-survey123/ba-p/895011
Neal_t_k
SD11
Thank you Neal!
The linked article did help me figure out the issue and resolution. The article refers to if you are using Survey123 connect xlsform.
In my case I was using the web designer and location question was set to collect the polygons (I should have clarified before). I noticed that by default the z values are active in the drawing tools for 'Points' and the survey was already published, hence I was getting the error even though the question was set to collect polygon areas.
Resolution:
I had to republish the survey saving as new survey and making sure that the z-values for points is disabled and then selected the polygon before publishing. It worked and no more errors!
Thank you
SD
