Embed Feature Report in OPS Dashboard?
1783
08-31-2023 09:42 AM
RHammers
I have not been able to figure out how to display generated feature reports in my dashboard, is there a guide on how to do this? I've looked around and can't find anything. Thank you!
jcarlson
Generated reports are standalone files. An embed would have to know the URL of the file, which depends on where / how the files are being saved when they generate.
We use a Make scenario to generate the report and attach it directly to the feature so that the generated report is available as an attachment.
- Josh Carlson
Kendall County GIS
RHammers
Make is similar to Power Automate, correct?
jcarlson
Should be, though I've not used Power Automate myself. But my understanding is they can do similar things.
- Josh Carlson
Kendall County GIS
RHammers
@jcarlson So I'm back to this again...
Do you know if this is possible in Power Automate? I have not changed any settings regarding where the files are saved, in fact I didn't realize that was a possibility. Did you do this within the ESRI ecosystem? I would really like to implement this.
