Editing multiple responses
689
11-28-2023 01:58 PM
achs
I've found that some of the data collected using a Survey is wrong, I usually adit the changes from the section "Data" in Web Survey123. Right now I have to modify close to 40-50 fields at the same time.
Already tried pulling the data in ArcGIS Pro from Portal and there I made the changes using the replacing option, the tool indicates that the changes where made, but that's not happening.
I'm wordering if the replacement is not being made because of any restriction or how could I made massive changes.
