Editing Existing Data Email
3046
02-05-2021 12:49 PM
JasonSimpson
I have a flow set up in Power Automate set to run when a new survey is submitted. With the exception of figuring out how to attach images from the newer multiline image feature, the flow works great. What I am trying to understand is how to send an email notification when a survey is edited. I have gone to the arcgis online webhook page and enabled the options for when a survey is submitted and when a survey is edited, but that does not seem to to help. This is important because we are tracking a site via a repeat section, so I need to send an email anytime a repeat item is added.  Any help would be appreciated. Thanks.
Tags (1)
ZacharySutherby
Hello @JasonSimpson
Since "New record submitted" and "Existing record edited" are enabled for the Trigger events the webhook should trigger automatically whether a new survey is submitted or an existing record is edited.
I had tested on my end with a public survey in Chrome set to trigger a webhook when a new record is submitted and when a record is updated and I am not seeing the same behavior.
What version of Survey123 is the survey using? Is there any difference between submitting as a public user vs a user who is logged in? Are there any differences between browsers?
If you open the f12 developer tools in a browser where the behavior is occurring specifically the network panel and submit an edit you should see a request to the payload URL shown on the Webhooks page for the survey. Are you seeing a request submitted to the payload URL when editing a record?
Thank you,
Zach
ZacharySutherby
Hello @JasonSimpson
Is your survey shared publicly, and being edited using the Webform in Internet Explorer or Edge?
We have a BUG (BUG-000134259) where surveys edited in that environment are not sending the update trigger for the webhook.
Thank you,
Zach
Thank you,
Zach
JasonSimpson
Yes it is public and I am editing the survey via Chrome. I am curious if I need to create an expression in Power Automate for when a repeat is added or if the trigger should automatically run whether I am creating a new survey or editing an existing survey.
ZacharySutherby
Hello @JasonSimpson
Thank you,
Zach
JasonSimpson
@ZacharySutherby
I am using version 3.11.164 and survey connect version 3.11.123. I am actually logged in as a user when submitting the survey.
When recording network activity, I notice the web hook has a status of 404. The information or that line is below.
Also enclosed is an attachment showing the error log.
JasonSimpson
Just as an experiment, I created a simple form with one repeat, tested it and the flow triggers when I edit the form. My original form has three different repeat sections with their relevance tied to an answer further up the page, so now I will try to add the remaining repeats to see if I can edit those as well.  I have to be honest, automating this process via power automate with repeat data has been quite a pain.
On a side note, can you guide me to any documentation that would help me pull only the newest repeat item for an email? I have an inspection form with with each repeat item within a repeat being a new inspection. I am looking to send an email notification to project managers once an inspection by our field crew is finished.
