Dynamically update survey123 range parameters
1632
04-23-2020 04:09 AM
Dean_McGowan
I have a number of range questions on a form, int_depth1, int_depth2 & int_depth3. Based on the value specified for int_depth1 I would like to update the maximum and minimum allowed values for the int_depth2 & int_depth3. Is this possible? I have tried two approaches without success.
1. Changing the parameters of int_depth2 to start=0 end=${int_depth1} step=5 but get an error specifying that all values must be integers. The default value of int_depth1 is 100 so it shouldn't be a problem with a null being passed.
2. Calculating the entire parameter string in a calc field (named calc_params) first and then specifying the calculated value in the parameters field for int_depth2.
Is there anyone out there with some ideas on how to move forward with this?
Cheers,
Dean
BrettStokes
Hi Dean,
Currently, dynamic start, end and step parameters are not supportable due to a limitation in pyxform which is expecting numbers. I'd like to encourage you to submit a request for this functionality via https://support.esri.com/. Similar requests from other customers can then be attached to the same enhancement request, which helps us assess demand for the enhancement and prioritize it accordingly.
Brett
