Dynamically Label SVG image via SVG Paths
2037
07-23-2021 10:19 AM
KristopherKerr
Hello,
I've got an oddball question that I'd like to throw out there. I have a client who would like to add a static image to each new survey and overlay data on top of it. The idea would be to generate a not-to-scale map image within the survey itself for the field worker to reference as they're completing their survey. I'm thinking of something akin to adding dynamic text to a map layout.
I've been experimenting with SVG images in Survey123 and I'm very familiar with using the "URL pop-up scheme" to generate a Survey by clicking a feature in a map and using the data in that feature's pop-up to preload a Survey with data. Is there a way to use this method to point data at paths in the SVG file and have it display in the Survey?
Any help or ideas would be appreciated.
Tags (5)
BrettStokes
Hmmm, I'm not sure I fully understand what you're trying to achieve here. Think of the 'image-map' appearance in Survey123 as just a different way to display a choice list, then perhaps this is possible. Try setting up your survey to pre-populate a value (select_one or select_multiple) from the pop-up of a given feature. Once you get this working as you'd like, add the SVG image and 'image-map' appearance. Then the SVG image will be displayed with the existing data values highlighted (as configured in the SVG <path> elements).
Brett
