duration from each survey?
2838
01-18-2016 02:15 PM
MarcoAmaya2
is there any way to check the duration time of each survey in hide mode? this is because our employed have a goal and sometime they use to fill by him self the surveys , if we have the time without his knowledge it will be useful.
Existe algun modo de poder saber la duracion de cada encuesta de forma oculta, esto es por que el personal que trabaja por numero de encuestas generalmente las llena con datos falsos para terminar pronto.
i tried use today but does't work
survey
typenamelabeldefault
todaytoday
JohnPlunkett
Hi Marco
You should be able to achieve  this is adding the start and end in to the survey
survey
typenamelabel
startstart
endend
These are hidden in the survey form
When you view the data in the FGDB you can see the start time and end time for the survey responses
JohnPlunkett
Hi Marco
survey
typenamelabel
startstart
endend
