Duplicate survey data output
2093
08-25-2023 01:47 PM
SeannaORegan
Hello,
We are building a form to submit samples to a laboratory for analysis. There are various different sites that would need sampled per permit. For each of the sites, we are trying to default the sampling bottles required, frequency of collection, and analysis required.
When the survey is submitted, the second site entered always duplicates the entries for the bottles, frequency, and analysis required. However, if you add a third site to the survey response, it doesn't duplicate. The site order doesn't matter, the second site always duplicates.
We are not sure how to fix it if you could please help! 🙂
notegenerated_note_surveyDescription<p style="text-align:center;">Name</p><p style="text-align:center;">CHAIN OF CUSTODY</p>
notegenerated_note_form_submit_textSubmit
notegenerated_note_form_footer<a target='_blank' style='color:#ffffff;' href='https://www.esri.com/products/survey123'>Powered by ArcGIS Survey123</a>
notegenerated_note_prompt_submitted<p style="text-align:center;"><br></p><p style="text-align:center;"><img alt="undefined" src="data&colon;image/svg+xml;base64,PHN2ZyB3aWR0aD0iNjQiIGhlaWdodD0iNjQiIHhtbG5zPSJodHRwOi8vd3d3LnczLm9yZy8yMDAwL3N2ZyI+PGcgZmlsbD0ibm9uZSIgZmlsbC1ydWxlPSJldmVub2RkIj48Y2lyY2xlIGZpbGw9IiMzMTg3MkUiIGN4PSIzMiIgY3k9IjMyIiByPSIzMiIvPjxwYXRoIGZpbGw9IiNGRkYiIGQ9Ik0yMi42NjEgMzAuMjQ2bDUuMTgyIDQuOTg3TDQxLjU1MiAyMiA0NSAyNS40NjEgMjcuNzQ3IDQyIDE5IDMzLjQ5OHoiLz48L2c+PC9zdmc+"></p><p style="text-align:center;"><br></p><p style="text-align:center;"><strong style="font-size:16px;"><p style="text-align:center;">Thank you.</p><p style="text-align:center;">Your response was submitted successfully.</p></strong></p>
textsampled_bySampled by<p>(your first and last name)</p> yesThis is a required question            255
textclient_nameClient Name   yesThis is a required question Client          255
textproject_numberProject Number      Permit Number          255
begin group
begin repeatSitesSelect Site
select_one list_site_codeselect_site Pick one:
textsample_descriptionSample Description   yes      ${select_site}='Other'
geopointcollection_pointCollection Point          ${select_site}
imagephotograph_sitePhotograph site          ${select_site}        method=cameramax-size=10
dateTimedatetime_sampledDate/Time Sampled          ${select_site}     esriFieldTypeDouble255
select_one list_regulatoryis_sample_regulatoryIs sample collected for regulatory reporting purposes?         ${select_site}
select_one list_site_is_site_flowingis_site_flowingIs it flowing >1 gpm?  minimal       ${select_site}      255
decimalfield_phField pH          ${is_site_flowing}='Yes'
decimalfield_conductivityField conductivity          ${is_site_flowing}='Yes'
select_one list_site_is_flow_calculatedis_flow_calculatedIs the flow calculated?  minimal       ${is_site_flowing}='Yes'      255
integerestimated_flow_rate_gpmEstimated flow (gpm)          ${is_flow_calculated}='No'
decimalstream_length_ftStream depth (ft)          ${is_flow_calculated}='Yes'    esriFieldTypeDouble
integerstream_width_ftStream width (ft)          ${is_flow_calculated}='Yes'    esriFieldTypeDouble
decimalstream_velocity_ftsecStream velocity (ft/sec)          ${is_flow_calculated}='Yes'    esriFieldTypeDouble
decimalflow_rate_gpmFlow rate (gpm)       round(448*(${stream_length_ft} div 2*${stream_width_ft})*${stream_velocity_ftsec}, 0)  ${is_flow_calculated}='Yes'    esriFieldTypeDouble
select_one list_frequencyfrequency_DSTF04Sample Collection Frequency:      Quarterly   ${select_site}='DSTF04' 0
select_one list_frequencyfrequency_USTF04Sample Collection Frequency:      Quarterly   ${select_site}='USTF04' 0
select_multiple list_bottlesbottles_DSTF04Bottles: UFUA = unfiltered, unacidified : UFA = unfiltered acidified : FA = filtered acidified    1L_UFUA,120mL_HNO3_UFA  ${select_site}='DSTF04' 0
select_multiple list_bottlesbottles_USTF04Bottles: UFUA = unfiltered, unacidified : UFA = unfiltered acidified : FA = filtered acidified    1L_UFUA,120mL_HNO3_UFA  ${select_site}='USTF04' 0
select_multiple list_analysisAnalysis_DSTF04Analysis      Flow,Cond,pH,TSS,Alkalinity,Sulfates,Hot_Acidity,Iron,Manganese,Aluminum,TDS ${select_site}='DSTF04' 0
select_multiple list_analysisAnalysis_USTF04Analysis      Flow,Cond,pH,TSS,Alkalinity,Sulfates,Hot_Acidity,Iron,Manganese,Aluminum,TDS ${select_site}='USTF04' 0
end repeat
textfield_76Special Instructions or Comments
imagerelinquished_byRelinquished by<p>Please sign your name.</p>signatureyesThis is a required question
select_one list_site_sample_dropis_sample_dropIs there a person to receive the samples?  yes
textsample_secureSample was dropped at secure location.Enter any other pertinent info about the samples' drop location.       ${is_sample_drop}="No"
dateTimedatetime_relinquishedDate/Time Relinquished   yes
imagereceived_byReceived by<p>Please sign your name.</p>signature       ${is_sample_drop}="Yes"
Tags (3)
TylerGraham2
I couldn't get the form to load or publish until I fixed labels, group names, inappropriate use of repeat count column and removed an extra "end group" at the bottom of the xlsx. I tested it in Connect and also as a published survey in Survey123 and it behaved as designed.  The only duplication I could see of the Frequency, Bottles, and Analysis fields is because you have default values set for each of those. That will cause the repeat to "duplicate" because it sets those as the defaults for each new repeat, but additional selections did not carry over between repeats.
There were some invalid cell values in the xlsx (empty fields that it didn't like until you clicked and hit delete) and some incompatible "type" and "bind::esri:fieldType" settings.  I fixed most, your stream width still needs fixed since the type is "integer" and the esri field type is "double". For your relevant expressions I changed them from the ${field_name}="X" to the best practice selected(${field_name}, "x").  I attached the cleaned up version for you to test out.
ZenMasterZeke
Do you have an end group? I also give groups a name and label (even if just <b></b>), although not sure that's mandatory. Do you have any calculations or other stuff going on?
SeannaORegan
Yes will upload the xlsx form 🙂
TylerGraham2
Would you be able to upload the xlsx for the form? It is hard to figure out where your formulas are supposed to be since the embedded table doesn't have any headers.
I'm surprised you aren't getting an error in the survey since it looks like your "select_site" field has no label name for it.
SeannaORegan
Hello, I have uploaded the xlsx in the reply above. I do get an error for not labeling the select_site but it doesn't seem to impact the actual survey and I can publish it.
Greatly appreciate any help you could give! 🙂
Thanks!
TylerGraham2
