Distress slider - appearance bug?
2310
7
05-25-2017 01:49 AM
DfIRivers
I have a Survey123 survey with an integer field that is populated using a slider (appearance set to distress).  the survey had been working OK, but now the appearance of the slider on the survey device has a large black box over the number.  Is this there a way to reset this?
Tags (1)
JamesTedrick
Esri Esteemed Contributor
This is on an iOS device, correct?  If so, we have an issue logged for this problem.
DfIRivers
Yes. Its on an IPhone 5s.
How long has this been an issue? and, Is there a timeframe for a fix?
AhnaMiller2
Having this issue on iphone 7 as well
JamesTedrick
Hi all,
This has been fixed with Survey123 2.3
AhnaMiller2
Thank you James, Do you happen to know if this version is available now and on all platforms? I'm not seeing a possible update in appstore yet
JamesTedrick
Yes, 2.3 should be available in all regions of the iOS app store - which region are you in?
AhnaMiller2
US, west coast. seems odd. I tried completely uninstalling and reinstalling and it had the 2.3 update. Thanks very much for your help!
