Display Map Based on Previous Selection
1943
09-16-2022 11:11 AM
EmilyMalvini
In Survey123, is it possible to set up a map question that would display a map based on the choice of a previous question? For more context, we have about 135 maps that show service areas for every product. If a user selects a product from a drop-down list, we would like the corresponding map to display. The map would be strictly FYI and read-only for the user. I'm creating this in Survey123 Connect and would like it to work in the web form.
Thank you!
@JamesTedrick @IsmaelChivite Maybe you would have an idea, since you were able to answer my other question at the ESRI UC. Thank you!
LaurenceTait
How many different maps do you have? It's simple enough to make an image visible based on a selected answer, but if you have large numbers of maps its going to slow down the survey loading.
EmilyMalvini
Hi Laurence,
We would have about 130 different maps that could be selected that are constantly changing so we would like them to show the most current map.
