Disable Predictive Text on Geocode Question -- XLSForm -- Survey123 Connect
4404
10
07-31-2023 09:11 PM
UH12
Hi all,
Very novice ArcGIS/Survey123 Connect learner here.
I would greatly appreciate if someone could help me disable predictive text/suggestions when a user is taking answering a geocode question on my XLSForm survey. The data in the geocode field is being fed on to a tooltip on a web map, and I think it's a bit odd that some fields have addresses (the user clicked on a predictive text result) and some don't (the user did not click on a predictive text result).
The closest I've come to a solution is via this support article under "suggestions."
To turn the predictive text feature off from its default setting (on), I've been going into the XLSForm spreadsheet under the body::esri:style column as directed and typing in "suggestions=no" and "suggest=no" and various other permutations but nothing seems to work.
I've linked my XLSForm spreadsheet HERE for review.
Appreciative of any help...thank you!
abureaux
MVP Frequent Contributor
Glad to hear it's working!
(And yes, that is the 'Field App')
