Disable GPS location
8125
13
11-22-2018 08:41 AM
NicolasRoger
My users have reported that the Survey123 app keep showing the following error message when they try to complete a survey with no GPS signal on their Android devices:
Basicly, what it says in english is : "No position received"
The actual position of the user is not important for our Survey (The user select a location ID). So is there anyway to prevent Survey123 from trying to find the device position?
Will autopopulating the geometry field keep the app from searching for a location?
Thank you for your help.
EDIT: I can confirm the same behavior appear on Survey123 version 3.1.113 on Windows 7. The message appear everywhere in the app. I now see that I can disable it in the App parameters.
Still, is there anyway to disable it completly? I would prefer not to collect personal information about the location of my users when they send me data.
Tags (1)
JohnathanHasthorpe
Hi Nicolas
The Survey123 field app will always include a location in a submitted survey, even if the form does not contain a geopoint question. This is because the data is stored in a feature service, and each collected feature must have a geometry. If the user does not want to share their location then they just need to disable the device location sensor - this will result in a null geometry being collected.
Cheers
John
Nicole_Ueberschär
If I turn off the location sensor I still get this annoying message. It seems like it keeps reminding me until I have defined/confirmed the geopoint.
BrandonArmstrong
Hi Nicole,
You can configure the display of these messages in the 'Alerts' options of the particular location provider settings. By default, the app will display messages and use text to speech announcements to inform you. See here for more details...
Edited: Quick reference—Survey123 for ArcGIS | ArcGIS
JohnathanHasthorpe
by Anonymous User
Not applicable
The Alert settings do not appear to help the issue. I have all of the alerts turned off, but when you launch the Survey123 field app (testing on Windows 10, app 3.6.153), it still throws an error. Perhaps it controls the alerts while inside a geopoint question in a survey, but the error still comes up on application launch, before opening any surveys.
Is there any way to disable this completely? Due to the presence of this idea, I'm guessing it is not possible at this time?
JamesTedrick
Esri Esteemed Contributor
Hi Shannon,
The error message you are showing is a system error (that concerns location), not a location error (which is affected by the settings mentioned above).  The ability to disable that message is being evaluated; for reference, it has been filed as ENH-000124021.
by Anonymous User
Not applicable
Thanks James!
ryanEvanczyk
Any update to this issue? Now the error is "location inaccessible" whenever I start the S123 field app. None of the machines we use need to collect a gps location. Locations are set on a map or not at all.
Thanks!
EricCaldwellAK
I agree with Ryan. We have office staff entering survey data with no XY data from their desktops getting this error every time they open the desktop app and we have to tell them "Just ignore that. It's an Esri thing." I'd much rather have a way to shut off this irrelevant pop-up.
