Disable GPS location
8255
13
11-22-2018 08:41 AM
NicolasRoger
My users have reported that the Survey123 app keep showing the following error message when they try to complete a survey with no GPS signal on their Android devices:
Basicly, what it says in english is : "No position received"
The actual position of the user is not important for our Survey (The user select a location ID). So is there anyway to prevent Survey123 from trying to find the device position?
Will autopopulating the geometry field keep the app from searching for a location?
Thank you for your help.
EDIT: I can confirm the same behavior appear on Survey123 version 3.1.113 on Windows 7. The message appear everywhere in the app. I now see that I can disable it in the App parameters.
Still, is there anyway to disable it completly? I would prefer not to collect personal information about the location of my users when they send me data.
Tags (1)
Anne-MarieDubois
Same here, I need to disable gps position for office workers. They must use the map to pinpoint the exact location and forbid the use of their actual location (to avoid mistakes).
IsmaelChivite
Esri Notable Contributor
I suggest you add a geopoint question to your survey and set the default column to null.  If you do not want to display a map in your survey, also set the appearance to hidden. I hope that helps.
Anne-MarieDubois
Unfortunately, I still need them to see the map to pin the needed location. I just don't want them to be able to use their actual location (GPS option) by mistake.
Shubhreet
I face the same problem as @Anne-MarieDubois . I do not want to collect any current location through the survey instead I have build my survey to retrieve static location from a linked .csv file using pulldata() function. The static is to be shown on the web map. Even when I disable the survey 123 field app to use location or disable the Alerts from the app, I still get 'Location inaccessible' pop-up which is annoying.
was anyone able to get any update on this?
