[DELETED] Required field - no blank spaces
1012
05-24-2021 03:50 AM
Teixeira
please delete this post, sorry for inconvenience, in the meantime a colleague managed to fix what was needed
____
Hello there,
I have a survey for easy-quick data collection of some equipments that are identified with numbers in most cases, so there's a field to be filled with that number - that field is required but the app lets the user to leave it blank with just a space entered...
Any way to restrict that? I don't want the first character of that field to be a space - I don't even need spaces there, even if the ID is something like "BL 13" I can have it "BL13" with no space, if that's what it takes...
We've tried the constraints of not(regex(., " ")) or regex(.,'^[A-Za-z0-9]*$') no success - and besides, they only trigger the error when we finish it, we're thinking of using character limitation >1, but that's not ideal
This matters because there will be a lot of users and some might want to cut corners...unfortunately
Cheers
by Anonymous User
Not applicable
Hi @Teixeira,
You should be able to delete your own post using the Options menu in the top right corner:
Regards,
Phil.
