Delete Survey123 Web Designer fields
1586
04-20-2023 11:34 AM
by Anonymous User
Not applicable
I have created a survey using the Survey123 Web Designer. I created a singleline text field and then later changed the question to single select. In the data tab I see 2 fields with the same name. How do I delete the original field? I have pulled all of my data into ArcGIS Pro and try to delete it there but receive an error.
I read that from the Data tab in ArcGIS Online there should be a check box next to each field for me to select and then delete but I don't see this option.
ZacharySutherby
Hello @Anonymous User,
You won't be able to delete a field from a view layer, you will need to delete it from the parent feature service that the _results & _form views point to:
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
