I have a workflow where users view the results of a survey in an Experience builder environment, using a table, feature info, and map. Using the URL parameters in the map/feature pop up they can open the survey response in the web app and edit the details. This allows for a more customized experience rather than using the Data page on the Survey123 website which they find hard to navigate.
Is it possible to enable an option for a user to delete a record either in Experience Builder or within the URL web app link? Or is this only possible on the Data page of the S123 website?
You can embed a full map into ExB. Then in that attribute table you can delete.
Other idea I am starting to use is the Edit widget in ExB linked to a new style web form (like Field Maps Designer but for the web map vs the Field Maps App - you find in the new map viewer). So you are creating a web form based on the 123 data and not using the 123 form. We do simple edits here so this has been working out. Yes you are double building forms a bit but it works slick since they can select in the table widget and the edit widget auto opens that record, then they can just hit delete.
There is a 123 widget also but I am not sure if it has anything different.
