Delete attachments from Inbox
414
06-08-2023 05:41 PM
GeoGeek
Is there a way to delete attachment/photo in the Inbox? I wish to delete photos captured before but it seems there is no delete function.
ChristopherCounsell
MVP Regular Contributor
I don't believe so, you can only add, not edit/delete per the limitation notes below:
https://doc.arcgis.com/en/survey123/desktop/get-answers/editexistingdata.htm#ESRI_SECTION1_47C2CB834...
https://doc.arcgis.com/en/survey123/desktop/create-surveys/prepareforediting.htm#ESRI_SECTION1_8D523...
This user indicates you can but I have not seen any method/notes to support it. Maybe another idea should be created:
https://community.esri.com/t5/arcgis-survey123-ideas/survey123-make-it-possible-to-update-or-delete-...
Also, photos don't download in the Inbox when offline. The survey form is downloaded, but photos only load when the survey form is opened (so won't have the photos if device has no internet connection).
Please support these ideas to allow inbox viewing of photos ENH-000158507
https://community.esri.com/t5/arcgis-survey123-ideas/support-offline-images-in-survey123-inbox/idi-p...
