Define how the increment a decimal or integer is increased by using spinner appearance
1113
01-05-2023 07:53 AM
AlexGilroy
Is there a way to define the increment a decimal or integer is increased by using the spinner appearance? I am trying to set a question where users can enter their hours spent on an activity in hours and would like to allow increments of 0.25.  I've tried using the range question type to specify this but it's not as user friendly.  I am using Survey123 Connect.
RobertAnderson3
MVP Regular Contributor
I see you found my post in the Ideas forum as I was hoping to be able to do the exact same thing, but I will post the link to it here for others as well!
https://community.esri.com/t5/arcgis-survey123-ideas/decimal-spinner-defined-intervals/idi-p/1054201
