Default values in hidden fields
4436
04-14-2016 12:25 PM
JaromHlebasko
I'm trying to create a hidden field that has a default value of "no". I have created the form correctly but when I publish it, the default value is blank in the feature service. Any suggestions?
HannahFerrier
Hello Jarom,
Unfortunately, this is a known issue in Survey123. You can workaround this issue by putting your default values in the calculation column. Please remember to include any string values in quotation marks e.g. "no".
Hope this helps,
Hannah
RobertMarros
Hannah,
I am trying to set up a hidden question in my survey but I am having an issue setting it up. Does hidden go in the type column or is it its own column and I need to type something into it (like yes or no)?
Thanks
