I am having trouble setting up my survey to use the select_one type for a hidden question. Is it possible to do this?
2186
05-05-2016 11:51 AM
RobertMarros
I am trying to create a survey where operators would go out in the field to
collect pictures for a survey and don't want them to see all of the questions I
am putting into my survey. My plan is to have them publish the survey out in
the field, and then have the survey be reviewed by an inspector back in the
office. During the inspection process, I would like to have questions created
by that same survey for the inspectors to answer, and those questions would
be a the select_one type (i.e. domains options).
Right now I am able to hide the questions, and see them in my schema for the
survey. However, my select_one "answers" (domain values) aren't
coming over after I publish my survey in the backend (in ArcGIS
Online). Is there a step I am missing?
TimothyBents
Instead of making the type hidden, try keeping the type as select_one and making the ones you want hidden relevant to a workcrew member named "office" or something that the onsite inspectors will not choose.
