Default values are being applied to fields that are not relevant
4412
10
07-24-2019 01:15 PM
DougBrowning
MVP Esteemed Contributor
We are seeing the default value being populated even when a field is hidden due to a relevant.  These should go to blank right?
All of these Live should be blank
Did it in 3.3 it looks like and still doing it in 3.5.
Causing a big data issue for us.
Anyone else seeing this?
thanks
ChrisRoberts2
Hi Phil
I found a solution.... I added the equation I had in the relevant column '${surveytype}="Fauna" or ${surveytype}="Flora"' to the body::esri:visible column and that seem to have solved my issue.
