Date formatting issues
1950
06-06-2023 11:55 AM
MatthewMorehead
I am trying to format the date in my survey into YYYYMMDD so that it shows up nicely in my instance_name setting field. I am currently trying to use the following formula to format the date in the calculation line of my date question :
format-date(${DATEOFSURVEY}, '%Y: %n: %e')
Connect keeps returning an error saying it is "invalid"
XLSForm is attached, any help is appreciated.
Tags (3)
ZacharySutherby
Hello @MatthewMorehead
The issue is due to the calculation being in the same line as the date question. This causes a circular dependency loop as a question cannot be calculated with it's own value.
If you don't need the formatted date stored in a field in the feature service you can take the same calculation and place it in the concat() function within the instance_name column. If you do want the formatted string in a field in the feature service you can add a calculate question following the DATEOFSURVEY question and reference that calculate question in the instance_name.
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
