Date Format
1267
04-05-2019 08:01 AM
HaroldHerrera1
Hello
I would like to know if in the last update of survey123 there was a change in the date formats or something similar. We have a problem with a Filter Group in an application in Web App Builder, which filters by the date all the records of a feature service with 6 tables.
Before the last update, the app worked fine:
but afterward, the filter does not build the correct syntax for the filter.
Any idea what it is about?
https://community.esri.com/thread/231691-group-filter-with-date-error
HaroldHerrera1
James Tedrick‌ do you have any idea about?
JamesTedrick
Esri Esteemed Contributor
Hi Harold,
It looks like this is an error in Web AppBuilder for ArcGIS‌, not with the survey data.  In the network request list, did a query request actually go to the feature service with the date limitation?
HaroldHerrera1
Thanks, James.
Today I try to configure the widget and works well.
