Data export is not working
1367
02-28-2023 12:49 AM
DrJumaKhudonazarov
Can anyone advise if there is a problem in general with the survey123  export data function?   I am getting an error for all my surveys and cant export any of the dates to Excel. Do other people have the same problem?
ZhifangWang
Hi @DrJumaKhudonazarov ,
Can you please share some more information to help us locate the issue?
  • Would you mind sharing a screenshot of the issue?
  • Did you export by using the "Export" button the data on the Data tab of the Survey123 website?
  • Is the survey created from Survey123 Connect or the Survey123 website?
  • Did you observe the same issue when exporting to other data formats, e.g. CSV, Shapefile?
  • Can you export the data of the source feature layer from the item details page in ArcGIS Online?
DrJumaKhudonazarov
  1. Above  screenshot
2. I use survey123website click on export and select  excel all was fine before
3.  survey created in connect
4, Have the same issue  with CSV, shapefile
5  cant export to future layer
DrJumaKhudonazarov
CSV   export is working now  but  the problem with Excel and shape file is still the same
