Data Entry Behavior of Field App - Windows
2623
05-08-2020 12:47 PM
bobwright
An end user pointed out various behaviors that I wasn't seeing, such as having to completely re-enter a value instead of being able to edit it, not being able to tab between fields, etc. Turns out I had v 3.6 something and they were using the latest version (3.9.149) of it. When I installed this version and compared the data entry behavior to the Android version (3.9.149) they appear to be identical. I assume this is intentional, though it does make Windows version entry more cumbersome. Thanks for any feedback.
BrettStokes
Hi Bob,
Just to clarify, are you saying you can't tab between fields or edit values using the 3.9.149 version of the Survey123 field app on Windows? You should definitely be able to do this. What Windows device / version are you using?
Brett
bobwright
Hi Brett,
Thanks for the response. I just tried it again and I guess I would revise my initial comments to say that it is pretty darn clunky, which it wasn’t with the previous version. Attached is the form I referencing.
Bob
BrettStokes
Hi again Bob,
Can you please confirm if you can tab between fields and edit values with v3.9 on Windows? I'm not clear on what you're saying has changed in the data entry behaviour between v3.6 and v3.9? Please let me know so I can investigate further.
Brett
bobwright
Hi Brett,
Sorry for the late response. I can tab between fields, and I can edit field entries, but it is clunky to the point that the users I work with brought it to my attention. I told them I was not seeing this behavior, but I was using 3.6. When I upgraded to 3.9.149 I was seeing the same thing.
Bob
