Custom URL support Map Image Layers?
1944
11-19-2020 12:25 PM
GISManager4
I am the following Custom URL in the pop up
arcgis-survey123://?itemID=bbcc61a5c2ee49bc9c07de759b02444f
but it does not appear to work on the Map Image Layer I am using to get the fire hydrants I want to be inspected. It just opens a blank web page.
When I view the same map in ArcGIS Field Maps, the pop-up configuration setting (with Custom URL) is not respected.
JamesTedrick
Esri Esteemed Contributor
Hi @GISManager4 ,
Can you provide information about what device the link is not working in?  If on your PC, can you confirm that Survey123 is installed?
GISManager4
I was able to get it to work.
