Custom report template select_multiple replace commas with new line
1068
08-11-2023 12:04 PM
Jamie_Leitch_CNF
I have a custom report template in MS Word format that I have added to a survey in AGO.  I have a question in the survey that is a select_multiple type.  When a report is generated using the template, the items in the select_multiple question are displayed all on one line with commas separating the choices.  I would like the choices to be shown in the report as one item per line.  I have tried using ${select_multiple | appearance:"bullets"} but as expected it displays the choices as a bullet list.
Is there a way to display the choices one item per line without bullets?  Or is there a way in the report template to replace commas with new lines?  Or is there another workaround to achieve this?
thanks.
