Custom DNS for Survey123 Forms
2815
04-18-2022 09:23 AM
ThomasKonzel
I checked online and in the ESRI Community but I didn't see an answer or question on this topic.  Just like the Hub sites can use a custom DNS entry, is there a way for Survey123 to use a custom DNS entry?  We would prefer that one of our citizen-facing surveys use our organization's domain name rather than the survey123.arcgis.com domain name.  Is this possible?
2 Solutions
IsmaelChivite
Esri Notable Contributor
Hi. You can do that by installing the Survey123 website locally.  This is not as straight forward as configuring a custom domain in ArcGIS Hub, but that is how you can do it.
IsmaelChivite
Hi @ThomasKonzel The main purpose of the installer is to support completely disconnected environments, but in your case you could install it in a public facing web server so you can benefit from having a custom domain for your Survey123 links.
IsmaelChivite
ThomasKonzel
Thank you @IsmaelChivite.  It appears that this local Survey123 website can only be installed for Enterprise behind a firewall using a reverse proxy to serve it to the Internet.  Is this correct?
IsmaelChivite
ThomasKonzel
Thank you, this is helpful information.
