Creating a View Layer
830
04-12-2022 07:24 AM
AmandaBeck
Hi all,
I have learned that it is not a good idea to create a web map that will be shared with a group using any of the layers created in ArcGIS Online after publishing a survey from Survey123. My goal is to create a View Layer from the Hosted Feature Layer that is created after publishing the survey.
When I go to do this I get an error message that reads "This view layer could not be created. Try again."
I realize that I technically could just share the stakeholder layer with the group and make a web map with that layer, but as I have read, I do not think that is good practice.
Any thoughts as to why it will not allow me to create the view layer to use in my web map?
Thank you!
IsmaelChivite
Esri Notable Contributor
@AmandaBeck  You may want to open a Tech Support case for this and connect with the ArcGIS Online team.
