Created nested questions based on a folder structure
1314
02-16-2024 10:20 AM
DarrylKlassen1
Hello, I am trying to create a survey for our field crews to sign off that they watched different videos.  I have it working from CSV files so when new videos or new folders have been created, they will automatically go into the survey.  I am (using PY) generating the CSV's that populate these questions, so it is dynamic.
For example:
My question is, if the user adds a 3rd level of folders and then puts videos in that folder, how can I dynamically create this survey to reflect that?  I.e. nested questions? Not sure how to deal with this based on the CSVs.  I can create the CSVs as needed, but don't know how to structure the survey to read them?
Thanks
Darryl
abureaux
MVP Frequent Contributor
Could you not set up a third level folder and have it just "waiting" for use? At some point, you need to tell the end users what the data structure looks like, and then stick to it.
abureaux
DarrylKlassen1
Yes, based on my 2nd question that you answered, I should be able to set up 4-5 levels of folders in my survey - then have a script populate the CSV with appropriate values (on a scheduled task).  Then tell the client that they are limited to that many folders deep.  Thanks for your help.
https://community.esri.com/t5/arcgis-survey123-questions/hide-select-one-from-csv/m-p/1383635#M54854
