Create Service error: Failed to create the service 'Hosted/service_699c6df871a248488d8d7f3e25a3bf78.FeatureServer'.
4718
09-09-2022 12:08 AM
melisco
Hello everyone,
When I try to publish a survey from Survey123 Connect app (both in versions 3.14 and 3.15), I receive an error mesage. I've tried to publish an empty template and still get the same error. Can somebody please help me with this issue.hata.png
Richard_Purkis
@melisco May you confirm if you are publishing to ArcGIS Online or ArcGIS Enterprise.
Additionally, please try and create a test hosted feature service on ArcGIS Online / ArcGIS Enterprise just by navigating to Content > New item. Is this successful?
Share how you get on
Thanks
melisco
I am trying to publish to ArcGIS Enterprise.
Also I tried to create a test hosted feature service on ArcGIS Enterprise but I recieved a error message as "Create Service error: Failed to create the service 'Hosted/test_feature_layer.FeatureServer'."
Thank you
ChristopherCounsell
MVP Frequent Contributor
Hi @melisco ,
If you are not able to create a feature layer at all it indicates that this is not a Survey123 issue but an issue with ArcGIS Enterprise. You will need to look at the server machines and ArcGIS Server logs to see why there is an issue i.e. is ArcGIS Server, ArcGIS Data Store running. e.g. here's a similar scenario where services can't be created:
https://support.esri.com/en/technical-article/000016577
Please don't forget the kudos 🙂
caemagisportal
olá, não consigo ter acesso a nenhuma formulário já criado no arcgis onlinne e nem consigo criar novos formulário pelo seguinte erro:
Create Service error: Failed to create the service 'Hosted/survey123_3203381ac6e443fda3d8b9244113ffb5.FeatureServer'.
