Hello,
is it possible in the Survey web designer to use a Single select option to then control what choices are available in a Dropdown if some of the single select choices also allow same matching selection in the dropdown.
I am not very experienced with the Connect app but discovered there is a way to do a one to one match of sorts for picnic tables but not for bences.
Below is the logic I would like to achieve if possible?
| Feature Type | Rule | Model |
| Drop Down (Single Choice) | Drop Down (Single Choice) | |
| Bench | IF Bench OR Available space for a bench OR Vacant but reserved | Streetmaster Clarendon Green |
| Picnic Table | IF Bench OR Available space for a bench OR Vacant but reserved | Cavendish |
| Available space for a bench | IF Bench OR Available space for a bench OR Vacant but reserved | Phoenix Jubilee Sea |
| Vacant but reserved | IF Bench OR Available space for a bench OR Vacant but reserved | Phoenix Bench (no arms) |
| IF Bench OR Available space for a bench OR Vacant but reserved | Plymouth | |
| IF Bench OR Available space for a bench OR Vacant but reserved | Glen Ogil | |
| IF Bench OR Available space for a bench OR Vacant but reserved | Rub/Queens Wave Bench | |
| IF Bench OR Available space for a bench OR Vacant but reserved | Haz Queen Mother Bench | |
| IF Bench OR Available space for a bench OR Vacant but reserved | Unknown Bench | |
| IF Picnic Table | Hillside Picnic Table | |
| IF Picnic Table | Hillside Picnic Table – DDA | |
| IF Picnic Table | Unknown Picnic Table |
So for example if user selects Bench from the Single choice they can only select from the dropdown 'Plymouth' and if they select Picnic Table, 'Hillside Picnic Table'
I hope this makes sense.
Thanks
Solved! Go to Solution.
Read this tips and tricks regarding choice filters, it explains cascading selects.
Short is you can add those custom "helper" columns to filter your choice list.
Yes, you will have to set up the second list with all the duplicate values. One for each option in the first list that you want that item to be available for.
