Create rule to control options in dropdown
1648
04-29-2025 04:08 AM
CMcDonald
is it possible in the Survey web designer to use a Single select option to then control what choices are available in a Dropdown if some of the single select choices also allow same matching selection in the dropdown.
I am not very experienced with the Connect app but discovered there is a way to do a one to one match of sorts for picnic tables but not for bences.
Below is the logic I would like to achieve if possible?
Feature TypeRuleModel
Drop Down (Single Choice) Drop Down (Single Choice)
Bench IF Bench OR Available space for a bench OR Vacant but reservedStreetmaster Clarendon Green
Picnic TableIF Bench OR Available space for a bench OR Vacant but reservedCavendish
Available space for a benchIF Bench OR Available space for a bench OR Vacant but reservedPhoenix Jubilee Sea
Vacant but reservedIF Bench OR Available space for a bench OR Vacant but reservedPhoenix Bench (no arms)
 IF Bench OR Available space for a bench OR Vacant but reservedPlymouth
 IF Bench OR Available space for a bench OR Vacant but reservedGlen Ogil
 IF Bench OR Available space for a bench OR Vacant but reservedRub/Queens Wave Bench
 IF Bench OR Available space for a bench OR Vacant but reservedHaz Queen Mother Bench
 IF Bench OR Available space for a bench OR Vacant but reservedUnknown Bench
 IF Picnic TableHillside Picnic Table
 IF Picnic TableHillside Picnic Table – DDA
 IF Picnic TableUnknown Picnic Table
So for example if user selects Bench from the Single choice they can only select from the dropdown 'Plymouth' and if they select Picnic Table, 'Hillside Picnic Table'
I hope this makes sense.
Neal_t_k
MVP Regular Contributor
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-choice-filters/ba-...
Read this tips and tricks regarding choice filters, it explains cascading selects.
Short is you can add those custom "helper" columns to filter your choice list.
Neal_t_k
Yes,  you will have to set up the second list with all the duplicate values. One for each option in the first list that you want that item to be available for.
CMcDonald
Thanks @Neal_t_k My setup looks a little different in that I don't have a Choices column.
Neal_t_k
CMcDonald
Thank you @Neal_t_k
Using that guide my setup now seems to work 🙂
