create rule on question list
1340
10-21-2024 08:04 PM
yockee
is that possible to create rules for the question items ?
suppose like this: there are 5 colomns, col1 to col5. I want to automatically hide col2 if a certain value is entered in col1. in other word, col2 is skipped.
thanks
ChristopherCounsell
MVP Frequent Contributor
Survey123 Connect
If you are referring to Questions, you can achieve this with a Relevant function.
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-hidden-relevant-an...
If you are referring to question choices, you can achieve this with Choice filters
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-choice-filters/ba-...
Both of these options may be difficult to apply to the 'column' of choices. You can control the appearance or order in which the choices appear, but not the visibility/columns/filtering themselves
For the web designer I'm not sure what options to have to apply this.
ChristopherCounsell
Survey123 Connect
