Create Question that Contains a Grid
205
10-04-2024 02:24 PM
MeKohler
Hi, I'm trying to create a survey which is meant to evaluate a web map in my organization.  I have a list of layers that I want the user to answer if they use or don't use.  I tried using the 'Single select grid' which would look like this:
This is working fine, but when I enter too many rows, I get the following error
Is there a way to fix this or is there a better type of question that I should be using?
Michael Kohler
abureaux
MVP Frequent Contributor
Sounds like there may be issues with your survey. Did you make it in Connect? If so, can you provide the XLSX?
There isn't a "cap" on questions, like what you've shown.
