Create a table-list in Survey123 with many select_one questions
3476
12-14-2023 01:13 PM
SarahLinn1
How do you create a table-list within a group with a bunch of questions that share a select_one question, like in the screenshot below?
DougBrowning
MVP Esteemed Contributor
It's called a single select grid now I think.  You use table-list appearance
See here  https://doc.arcgis.com/en/survey123/browser/create-surveys/quickreferencecreatesurveys.htm#ESRI_SECT...
It was hard to find for some reason.  Hope that helps
ZenMasterZeke
One caveat is that you can't have a conditional question right after the select question. For example, if a user selected 'Dislike' above, you may want a text question to display asking for details about what they didn't like. While you can have these outside the table-list, you can't have them directly after the select question.
jcfernandes
Hello,
In Survey123 Connect, I want to use the hint and guidance_hint, but they are not configured on the correct lines. Instead of appearing below the question they are configured for, they appear above it.
Could this be an error?
Thank you
Best regards,
João Fernandes
AbdulabnanMohammed
@jcfernandes
I'm looking for something approach in my survey123
Can you share the sample template of this , So that i can approach
I shall be thankful to you
