Count formula to add results from a number of single choice fields
690
01-23-2023 11:04 PM
TobyChapman
Hi there,
I have created a survey in survey123 connect for auditing which has a number of single choice fields.
Each of the choice fields have an option for pass, fail, N/A
At the top of the form I would like to have a note that counts the number of fails but I can't seem to find a calculation that will allow me to count based on a selection.
I tried changing the choice results to 1 for fail and 0 for pass and N/A and then simply adding each question but it lists the zero's in the results.
Is there a way to count the number of fails?
One other thing I would like to add is a note that lists the audits that failed.
Is this possible?
Any help would be very much appreciated.
JenniferAcunto
If it is listing the zeros in your response, I'm guessing it is treating your values as a string and concatenating them. You will need something like
number(${question_one}) + number(${question_two})
- Jen
