Constrain integer field to be not empty
3073
07-28-2020 12:09 PM
TomSchwartzman
I have an integer field called num1. Has a default of zero.  But you can erase that zero and leave the field blank.  This blank field is not considered an integer (kills calculations for instance).
I want to put a constraint on it so you don't leave it empty (i.e. no number, no text).  I can't seem to do it.
I have tried testing to see what this "empty" integer field is interpreted as, and I can tell you this:
${num1}=''   is FALSE
${num1}=NaN  is FALSE
number(${num1})  is BLANK
string-length(${num1})  is 0
string-length(number(${num1})) is 0
string-length(string(${num1})) is 0
here is the survey with the num1 field empty:
empty
and here with the num1 field with a valid number:
survey
I tried using any of these in a constraint (e.g. string-length(.)>0 ) but that is ignored, or not seen as an issue as it happily lets me submit with this blank integer field.
s
Is there a way to constrain it?
I have worked around it by using a calculation in another field, but was hoping I would not need to do this.
survey123 xlsx attached.
Tom S.
P.S.  ${num1}=null is FALSE, ${num1}=undefined is FALSE as well.
DougBrowning
Does required work?
I had an issue for a bit that you had to use string-length != or = 0.  >0 never worked - not sure why but could be that it is considered text.
Hope that helps.
TomSchwartzman
Thanks Doug for the reply.  Yes, required will do it, but I don't want to make it required if I don't have to. Maybe there is no difference between required and constraint of a number/digit, have to ponder that.
My workaround was to make that field a null field and add another field that was calc'ed via an if statement, which honors the string-length query (if(string-length(${num1})=0,0,${num1})
Tom
JamesTedrick
Esri Esteemed Contributor
Hi Tom,
In Survey123 terms, a required field is a field that must not be blank - you should make the field required.
Another approach would be to wrap the the question in coalesce(${q}, 0) to provide a default value when blank.
Katie_Clark
MVP Regular Contributor
Hello, I know this thread is older but I stumbled on it when I was troubleshooting something in a survey and wanted to post a link to some useful esri documentation on empty values.
Particularly relevant to this particular post:
  • Empty values for integer and decimal questions are represented as NaN (not a number). This is a special value that represents the absence of a valid value.
  • The NaN value compared to any other value is only true in a calculation of an is not equal value comparison. All other expressions result in false.
Hope this maybe helps someone!
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
