Conditional
1989
06-17-2021 08:32 AM
ElizabethWheeler
Could I create a question that is only visible if a preceding response's string contains 'abc'.
More specifically the preceding response is a string of one or more agencies and the conditional questions would only be visible if one of those agencies were listed. The 'preceding response' is pulled from a csv. I am using pulldata for that question so I could not make the type a select_multiple nor is it appropriate for a select_one type.
DougBrowning
Have you tried
contains(string, substring)   Returns true if the given string contains the substring.   contains(${question_one}, 'red')
DougBrowning
Have you tried
ElizabethWheeler
That's the one. Thanks Doug
DougBrowning
