conditional statement
857
01-15-2021 03:48 PM
chiragtiwari
Dear Colleagues,
I have the following statement:
if(selected(${item_on_path}, 'other_unsafe') or selected(${item_on_path}, 'dontknow') or selected(${item_uxo_on_path}, 'setonfire') or selected(${item_on_path}, 'takeithome') or selected(${item_uxo_on_path},'taketoauthorities') or selected(${item_on_path},'buryit') or selected(${item_uxo_on_path},'movetosafeplace'),0,1)
in this survey i have 3 age groups: 6-10, 11-17, and 18. I would like to change this conditional statement to have an "if" clause.  If ${age}='6-10' than (${item_on_path},'mark it'),0,1) as well.
any suggestions?
Alber_Verster
What is the exact problem here? Does your first statement not work or are you looking for advice on how to change it?
Regarding your second query, the provided logic does not satisfy the If-then-else conditional workflow.
You would expect something like this:
If(selected(${age}, '6-10') and selected(${item_on_path},'mark it'),0,1)
You could also have a look at the documentation on formulas provided by Esri here:
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
Hope this helps.
Alber
Alber_Verster
Hope this helps.
Alber
