I am using Survey that opens from Collector to autopopulate fields. I have successfully been able to modify the submission URL of a feature service to get some fields but I was wondering if there was a way to pull data from other features.
example: there are 3 relevant features:Parcels (polygon), Poles with the Survey link (point), and Inspections being created in Survey123 (point). I want to be able to pull the ParcelID from the polygon into the Survey.
Is this possible or am I being ambitious?
Collector (Windows 10): 18.0.1.0
Survey123 Connect: 2.8.4
Survey123 Desktop: 2.8.2
Hi Alicia
You would need to use the beta JavaScript functionality described here: Welcome to our Feedback Community
With some basic development skills, you will be able to perform a spatial query against a polygon layer and use the returned attribute to populate a question in your form.
John
