Collect information and print in bullet point format
559
11-28-2024 08:14 AM
PanGIS
Hello,
Trying to figure out if it is possible to collect information in a text box and then transform the automatically in bullet point (in a Report).
I read that is possible to do it with a select multiple but here I need free text as there is no choice and bullet point could have 1 or 10+ entries.
Solved: Word Report 'Bullets' format - Esri Community
Any idea?
Thanks!
j-bromp
Could you use a repeat and get the user to treat each repeated text box as a bullet point? then format your report to use bullet points?
abureaux
MVP Frequent Contributor
is [it] possible to collect information in a text box and then transform the automatically in bullet point (in a Report).
No.
As @j-bromp pointed out, a repeat is the only option.
