I created a custom form template from my watershed patrol survey and when I use it to export the report I'm getting this error print map failed for ${ activity_location }:{"error":{"code":500,"message":"Error performing execute operation","details":[]}}.
Before I created the custom template I actually downloaded the default template of the survey, then used this as a template without any custom formatting and I was able to produce the report in word with no problems. The report included geo points, pictures and repeats etc.
I'm assuming there has to be some placeholder out of place, unfortunately I'm having a hard time trying to figure it out. I have attached the default template as well as the custom one I created to see if someone would be able to look at both to see where the issue is coming from.
Thanks in advance,
Todd Hill
