choices font
1844
08-06-2018 11:13 AM
DanielSalazar1
I am currently developing a survey using Connect, for Senior Services Department, the purpose of the survey is to serve as a Check-In for daily activities and if they are eating lunch at the Senior Services Facility. One of the main concerns is the Survey Choices font is too small. The clients will be ages 65 and up, the eye sight may not be the best.
Is there a way to change the font size of the Choices list?  or if any one has any other solution to the problem.
JohnathanHasthorpe
Hi Daniel,
In the field app go into settings and you will see a text size slider. You can push the value up to 200%.
This should help things.
Thanks
John
JohnathanHasthorpe
Hi Daniel,
Thanks
John
