Choice filter with Dynamic Lists
1282
02-23-2024 05:51 AM
GeorgeF
we are using the dynamic list capability to store about 8 different tables.
Some of these tables need to be related (i..e choice will filter results of next table).
We used to do this with a separate CSV and a choice filter, but because of thousands of records and frequency of updates we moved to dynamic lists.
Is it possible to filter the results of a dynamic list, based on the selection of a previous dynamic list?
Thank you,
abureaux
MVP Frequent Contributor
Cascading selects
EDIT: WHERE clauses and search options are also helpful to look into.
GeorgeF
Thank you.
Do cascade select work with tables stored in AGOL referenced through the "search" expression?
GeorgeF
I was wondering if there is an update on this as I havent been able to make cascade selects work with Tables hosted directly in AGOL.
Thank you
